thanks but I do not understand ....
Kuby says:
"Change the input transformer from 10k:10k to 600:10k. Can be the same like the output transformer. 1:3 is cool, too.
600Ohms is high enough to be driven from any professional gear from the last 60 years. The changed transformer will give you additional 12dB gain at the input which you might really need as the compressor needs to be driven hard. It will also marginally improve the noise figures as a side effect due to the lower resistance. "
you advice 10K: 10K?
thanks
Kuby says:
thanks
