hitchhiker
dressed in black! that is a sweet build.
Unit-8 said:Hi all,
After completing all tests and had a long burn-in for tubes as well as for audio transformers i confirm the quality of this compressor. I really love it!
Here are a few pictures.
Unit-8 said:Hi all,
MicDaddy said:FWIW I was able to manage fitting 1uF @ C102, C104, C105
There are power resistors underneath the caps. If it gets toasty I plan to remove the resistors @ R11 & R7 & R18 and stand them on end/vertically so they don't fry the undersides of the oversized capacitors.
There was talk of a pole in the sidechain which caused LESS gain reduction with more low end signal, which is what I'm trying to avoid.
MicDaddy said:That is an option, but then no pretty red boxes to look at 8)
no. even if we would live with total different characteristics it is not dual element.justinheronmusic said:Ok, so I checked out Small Bear. Are these Vactrols going to work?
http://smallbear-electronics.mybigcommerce.com/photocouplers-macron-mi1210cle-r/
rock soderstrom said:Yes and yes. My thermal paste is not really conductive.
