scott2000
R105 ,R107 the right value?
Can I measure the plate resistance somehow sensibly? (This is my first tube project, I might ask silly questions)How's the plate resistance tolerance on these ECC81/12AT7 tubes?
If everything else checks out fine the difference in voltage could be due to difference in plate resistance between tubes....
I seem to remember I got antsy to check voltages and found discrepancies , posted here ( not sure when ) and made the same statement about not having the pots in yet , when I put the pots in the circuit and retested - all voltages checked out good.Ah good call, checked, they are 47K and 10K resp, like the BOM :/
Just in case, I will trace back the values using the schematics, double check any divider that is in play.
Hmm all resistor values look ok.
Could it be because the board is not (yet) connected to any potmeter?
Yes, I posted on pageb69 of this thread , look at my voltages , that was without pots , after I installed pots , all voltages were good.Ah good call, checked, they are 47K and 10K resp, like the BOM :/
Sorry, I made a mistake while looking at the PCB pic you posted earlier. I don't think it's the plate resistance.Can I measure the plate resistance somehow sensibly? (This is my first tube project, I might ask silly questions)
Thanks! When I searched for "voltages" (plural) your post didn't match, my bad.I seem to remember I got antsy to check voltages and found discrepancies , posted here ( not sure when ) and made the same statement about not having the pots in yet , when I put the pots in the circuit and retested - all voltages checked out good.
Thanks for your comment Scott, no not yet, we found out that the missing pots are the cause of our 130V difference from spec. Voltages will drop when the pots are installed.Are pots installed?
Ohayo! Yes, since most of us do not use it in live concert situation with cable runs of >100m, it can run unbalanced fine (see: What are you using your D-AOC on? Switchable transformers?).In general, I think this circuit doesn't really call for input transformers at all. Can feed unbalanced as is or -- and this has crossed my mind -- add IC debalancing instead, which might be sacrilege for some, but definitely cheaper and probably also 'cleaner'.
