Purplenoise
- Joined
- Sep 19, 2019
- Messages
- 535
I believe Oliver came up with the 5.05v setting mostly to bring the impedance closer to a vf14...or closer to what a 6.5:1 transformer wants to operate optimally. Some say that ef800 tubes work better with a 12:1 ratio transformer. It would be interesting to see if for example at 5.05v you get more low end than 6.3v. If you do the experiment I would be very curious about your findings.JMPGuitars said:This is true. Some tube datasheets include information for what drop in transconductance can be expected. For example, the 5840 datasheet says with 5.7V heaters, you can expect a 10% drop in transconductance.
The interesting thing is that low transconductance can also be a sign of a dead tube. For example, EF800 datasheet says if initial transconductance value drops to 5.4mA/V, that's a dead tube (EoL).
I wonder if with lower heater voltages / operating proportionally at a lower transconductance 1. really increases tube life as some believe; and 2. if a tube that was considered EoL on standard voltages would be usable at lower heater voltage.
Assuming an EF800 and the drop being proportional (and it isn't always), then a 20% drop would be 6mA/V, which is still within a good range. If one of the tubes I receive isn't great, I'll try and measure the transconductance at lower heater voltage and see what comes up.
