dasnevestheo
- Joined
- Oct 6, 2017
- Messages
- 188
you need either the microphone or dummy loads connected to the PSU to see the correct voltages or they'll be much higher
Use the current draws in Dany's schematics to get a rough idea of what resistors to use as dummy loads for testing
Do you have any high wattage resistors? 1W? 2W or different value?Can't find these schematics. I've read this post... dummy load for tube mic power supply?
So I know that 1/4W 150K to 210K should work for B+ and 20R to 30R 2W for H+
I have for sure a 1/4W 150K resistor, but don't have a 30R 2W so should I get one to my local dealer or do you think I can swap this H+ rough calibration with dummy load and just plug the mic in and then calibrate H+ ?
I was in the same situation and ended up pluging the mic for the calibration, praying not to roast anything. I was luckyCan't find these schematics. I've read this post... dummy load for tube mic power supply?
You could put four in parallel to get you close enough. Adjust your heater a little high then you'll be in the right ballpark to connect your mic.Yes I have but far from 20 or 30R... The lowest 2W resistor I have is 51K. I also have some vintage carbon 1W 150R resistors
+27V is not wrong. The mic needs to be connected to drop that voltage down. The tube requires about 300mA of current.Well, I inverted the bulb socket wiring and no more bulb or fuse blowing. I wired the heater transformer and measured H+ and I get a huge 27VDC... What did I miss or do wrong ???
Yeah, he could parallel a bunch of them...Could work in a pinch but...Or if you have a bunch of small value 1/4W or 1/2W you could make a network to get close.
I didn't use the ttpump for the heaters, i used a 317 from the same 12v wallwart feeding the ttpumpFollowing as I have the same Chinese BV8 from AliExpress. Also how did you get the 6v filament voltage from the TtPump?
Here's a Soundcloud playlist that has me singing the same lines from a song using my D-EF47, once with a Mullard EF-80 tube and once with a Telefunken EF-802.
Since I'm using a 'stock' AMI power supply, I haven't messed with the heater voltage at all--I tried building my own power supply based on the schematic, but I was in over my head once I got to the wiring stage.The Telefunken EF802 is my preferred too. More defined, smooth shinny highs. Did you adjust the heater voltage or was it the same for any type of tube ? I've read few pages before in this thread that for some kind of tubes, the heater voltage had to be encreased a bit. And what would have been even better, is to compare the Telefunken with other 802s from other brands. Just to see if Telefunken worth their price or not.
Interesting! Hadn't heard of anyone using a PF86 in this circuit. I wonder if it's worth trying in my mic, considering I don't have the capability to adjust the PSU.The 802 was my fav at first as well, beautiful highs, overall clarity (i'm using a National 802)
Then i tried 806 S from Tesla, to me it sounded more like what people would call 'vintage', it's a nice thick sound, could be great on instruments
Then i tried pf86, from philips, mazda and telefunken, all sound great but the telefunken definitely has the edge for vocals, it gives the microphone that 'magical' thing. I was eager to try that to see if telefunken stuff was more a myth than a reality, but it sounds super great, it's true lol! I've got two telefunkens, both sound different, one has more lows which i found weird, but it's the one i picked for the singer i made the microphone for!
The philips and mazda sound like they'd be great for a preamp, more for uncolored amplifying, i think the telefunken tube gives the microphone a color that is what people would expect to hear from a 'tube microphone', at least for vocals, i don't know if you'd want that kind of sound on everything!
It's too bad we can't attach audio files !
