HI Guys,
I just completed this project. Have to say, am super happy with the sound. Really nice texture and dead silent! I will put it through its paces with proper vocal recordings. Thanks to
@poctop for the great PCB,
@wrentema for his insights and help. My dad for the (electronic) guardian angel he is and of course Oliver...<3
I went roughly the same way wrentema did. The body I got from Aliexpress. Well build and finished. From the inside a bit simple though. I had to be a bit creative getting the pcb in there and make it tight. The t47 transformer I got from AML, I bought some nos Telefunken EF800's and the Blueline M7 capsule from Thiersch.
The shockmount I also got from Tab Funkenwerk. For the clips to close the spider I had to made a solution as the Aliexpress body is a bit thicker. I fixed this with simple iron wire with a shrink tube over it
Some difficulties I had with the build was the PSU, I bought the beautiful PSU housing from Tab Funkenwerk but it was made for an original point to point wiring I guess (?) there was a metal sheet in there with holes for caps or something. I had to put the multitool to use and get it out. Then I had to arrange the custom big screened Torroid (from audiophonics), choke and pcb in a way it made sense. I made sure the 5W 50 Ohm Heater voltage potmeter made contact with the housing so that it could transfer it's heat easier.
I made sure the grounding was tight: 1 star point in the PSU where the powersocket ground is connected to, the screen of the torroid, the housing and the 7 pin XLR ground. The 3 pin XLR I connected straight to the 7 pin. In the mic I made sure there was one point where I connected the housing to the pcb. Of the PSU-PCB I did not connect the 0V line. (as this is ground and I thought it better to use just 1 connection from the pcb to the ground which is connection "7". On both the XLR plugs I connected the 'sleeve' with the ground pin.
Another difficulty I had was calibrating: With the 30 Ohm test-load resistor I never got get the H+ to 5.05v. It was always too high (lowest I got was around 6.5V). With the mic plugged in this was easier. I made sure to let the mic heat up for about an hour or so to make final adjustments, then I got easily to 105V on B+ and 5.05V on H+ (here with 240V so all resistor values are cool). It takes a serious amount of time to stabilize. The 150k resistor worked well to get into the ballpark.
I was pretty secure with making sure the 7 pin XLR connector had the right signals / voltages going over them:
1: Audio -
2: Audio +
3: Extra ground.
4: H+ (the thick wire in my Sommer cable Octave Tube)
5: B+
6: Pattern
7: Ground (the other thick wire in the Sommer tube cable)
Other info:
The little polar pattern badge I got from Ebay (opus1374), switches and lights from Conrad, The Mic case from
[email protected]
Thats about it. Can't wait to record
Thanks everybody for their info and insights!
