AB_Music
Member
@mrgrooves666 probably means how to protect the capsule with the zeners.I posted here a grounding diagram. Make switchable the audio gnd and avoid ground loops. Use stargrounding.
I would also be interested how to do that
Highly recommend powering the relay via the filament supply, like it should be.@mrgrooves666 probably means how to protect the capsule with the zeners.
Rs relays are either 12v or 48v for this project so you cannot run from the 5v heaters. Zener calculations are easy guys you need a limiting voltage,and add a loading resistors to gnd, thats all. Use a zener with a bit higher voltage, so it wont add noise when the mic is working properly. Add zener to the pattern 50v too. Problem with this design is that the relay consume equal or more power than the mic tube. Vintage mics derived the pattern from b+, (see c12, or m49 patterns schemos) but there is no consumption at all (capsule needs pAmps maybe)Highly recommend powering the relay via the filament supply, like it should be.
Regarding grounding issues,
-You mentioned the mic cable shield and Ov are tied together on pin 7. Is the cable shield also connected to the connector chassis on both ends of the cable?
-Inside your PSU, IEC ground pin should be connected to the PSU chassis, as well as Ov. Ideally the resistance between chassis and Ov is the same as your DMM leads resistance. (There's also another grounding schem..., however I don't want to cause confusion)
Hopefully there's enough info. above to get your issues sorted.
-Cheers
I haven‘t changed anything in the design of the provided pcb, so the relay is powered how it was designed. Also don‘t have the electrical knowledge to change it…I can just build these things like a „sort of“ Lego set.Highly recommend powering the relay via the filament supply, like it should be.
-Cheers
Maybe it's a bit late reply, I had some buzz issue with my first try. After I saw some thread, tried cut shield connection and also cut connection of chassis and connector of PSU side, the buzz was gone. On mic side pin7(cable shield)connected with microphone body. And I also cut ground and shield connection(pin3-7). I'm a newbie for a mic build, so it may not that helpful with your situation, but it worked for me.I haven‘t changed anything in the design of the provided pcb, so the relay is powered how it was designed. Also don‘t have the electrical knowledge to change it…I can just build these things like a „sort of“ Lego set.
Anyway…yes shield and ground wire of the cable is tied together…they are also both connected to pin 7 and the ground terminal of the 7 pin connector on the psu side…on the mic side the connector has no extra pin for grounding the housing (see pics)…so shield and ground wire are only connected to pin 7 on this side of the cable.
In the psu ground goes to pcb and chassis.
DMM reads good connection for both ground points. But it was my next idea to redo these connections.
You can wire it up as you want, com in center lug obviously. Up to you to choose to have cardioid in left or right position.How do you wire up the pattern switch? I assumed com to the center lug of the switch in the BOM and omni and cardioid to the other two lugs respectively.
What confuses me is the diagram at the top of page 16 which has cardiod and omni wired together on one of the outside lugs and a connection to 0v on the other lug. Is this malarkey or should I wire it this way?You can wire it up as you want, com in center lug obviously. Up to you to choose to have cardioid in left or right position.
You can find the informations about it on page 15. And in the BOM, there are both transformers(115/230), so you can select one for you.Hi All,
I’m thinking of building the DEF47 in the UK - I wondered if anyone on here might know - are there any alterations I need to make to the PSU transformer to work with the UK voltage?
Many thanks
Silas
I wired com to center tap, crd to left and om to right. It works flawlessly. Of course you can swap left and right.What confuses me is the diagram at the top of page 16 which has cardiod and omni wired together on one of the outside lugs and a connection to 0v on the other lug. Is this malarkey or should I wire it this way?View attachment 96723
