Brian Roth
The highest voltage anywhere in a 2254 will be 24 Volts from the power supply. The voltages in that section of the BA185 will be a tiny fraction of that.
Bri
Bri
Thanks Brian, I will get the ones you mentioned for the second kit I have.The highest voltage anywhere in a 2254 will be 24 Volts from the power supply. The voltages in that section of the BA185 will be a tiny fraction of that.
Bri
Thanks for your reply Scott. So I assume that you are saying there would be an advantage to using the 5uf over the 4.7uf. Is my assumption correct?if height/size is ok do you have enough leads on the axial to just mount them vertically? I've done it before with some heat shrink added to the leads
I'm not familiar with this project. I'm pretty sure 4.7uf caps were available when this project was realized .. Couldn't tell you why they wouldn't use them. Maybe someone familiar with this will have an answer. Seems like pretty tight tolerance....Thanks for your reply Scott. So I assume that you are saying there would be an advantage to using the 5uf over the 4.7uf. Is my assumption correct?
Thanks Scott. I'm hoping...I'm not familiar with this project. I'm pretty sure 4.7uf caps were available when this project was realized .. Couldn't tell you why they wouldn't use them. Maybe someone familiar with this will have an answer. Seems like pretty tight tolerance....
In situations like this I’d go with the 4.7uF, order 10+ for the price break from Mouser, then measure them and pick the one(s) closest to 5uF if I want to be precise. I had to do this same thing recently while rebuilding my Farfisa. Depending on its function in the circuit, it may not matter though. With the 20% tolerance accounted for, I’d imagine they can be anywhere from 4-6uF and be fine.Hi everyone,
I have a question on the BA191 pcb build; According to the BOM C14 is 5uf/25V electrolytic capacitor in radial configuration, but I can only find 4.7uf/25V in radial. I did find 5uf/25V in axial configuration. What do you think? Which one should I use?
And thanks Migs, I definitely am having fun!
I definitely will do that! Thanks for the advice.In situations like this I’d go with the 4.7uF, order 10+ for the price break from Mouser, then measure them and pick the one(s) closest to 5uF if I want to be precise. I had to do this same thing recently while rebuilding my Farfisa. Depending on its function in the circuit, it may not matter though. With the 20% tolerance accounted for, I’d imagine they can be anywhere from 4-6uF and be fine.
Thanks for the perspective Ilya!4.7 vs 5 uF are basically the same. One is an older standard, another is a newer one. You can put in whatever you have at hand
No worries, I just cut off the right angle part of the solder legs and it fit just fine.Hi Everyone,
Does anyone know the correct power switch to order for this build? The designer specified the wrong part number (A101MD9AG04 - it is a right angle switch).
