rock soderstrom
Tour de France
Hi guys,
I'm just thinking about this topic. A real example would be a tube spring reverb device which is supplied with 9V-12VDC via an external wall wart.
The voltages required for the tube circuit are then generated inside by a PCB like this for instance.
In the event of a fault, a dangerous high voltage on the case or other metal parts (e.g. front panel of a wooden housing) would be possible. As there is no PE connection to ground, the normal safety mechanisms (e.g. RCD fuse) will fail.
I would now insulate this device with a second inner metal housing in which all high-voltage potentials are isolated so that it is not possible to touch them, even in the event of a fault.
I think this is called IEC protection class II, right? However, the focus here is actually on the mains voltage, which is similar high to the B+ of conventional tube devices in my area. I therefore consider the situation to be comparable.
A Class II component, or open frame power supply, needs no earth connection for safe operation. The minimum distance from any live part to the enclosure must be observed whether it is conductive or not in order to maintain the two levels of protection needed against a single failure in the system. The use of a Class II external power supply is straightforward, with the main difference compared to a Class I product being that it requires only 2-core main leads for secure operation. Protection is maintained by double or reinforced insulation, rather than relying on both protective earthing and basic insulation. In this way, IEC Class II power supplies are not mandated to have a safety ground conductor brought to the power supply."
What do you think, how would you proceed, what do we need to consider?
"Class II power supplies
