Thanks for the Reply Rob
Below is what I have in my notes for the calibration - is none of this really needed?? Would be awesome if that is the case !
Test Equipment required:
- Low distortion Audio signal generator.
- Distortion Analyzer or Meter Trimming tool.
For each channel :
1) Take out the tube in the sidechain smallest (6AL5) tube.
2) Let the other tubes heat up for a few minutes.
3) Split a 1kHz signal and feed it into your input tube (connect the same signal in phase to pins 2 and 7 of the ECC85) reference to ground.
4) Set the trimmer between the ECC85 and ECC81 (DC Balance) for the lowest output signal possible.
5) Disconnect the Signal.
6) Connect a 50Hz signal to the "Link" point on the PCB
7) Set the trimmer next to the ECC85 for lowest output signal possible
8) Repeat everything from step 3 until no more reduction on output can be achieved.
9) Reset the GR meter trimmer with no signal applied to 0dB.
___________________________________________________________
5.2 Meter Alignment
Under no circumstances use the meter mechanical adjustments on the meter front to correct readings.
The electronically ‘zero biased’ meter settings will require periodic re-adjustment. The metering circuit is necessarily very sensitive, change from the ‘zero’ position is quite normal and is not a cause for concern. The causes are normally slight
changes in valve performance due to ageing or variations in
the mains supply voltage.
5.3 Meter Adjustment
Procedure:
1. Turn power on, wait for five minutes for the unit to warm up.
2. While waiting, make tea or other refreshing beverage.
3. With no signals present at the input, ensure Input Level
controls are turned right down.
4. Set Threshold to ‘zero’, Attack to ‘Fast’, Release to ‘Slow’.
5. Ensure Stereo Link switch is in ‘up’ position (no linking).
6. Use a trimming tool or small instrument screwdriver turn the
appropriate multiturn preset located on the front panel below
the Power and Stereo Link switches until the meter needle
is at the ‘0’ position on the scale.
7. Repeat procedure to other channel.
8. Drink tea or other beverage.
5.4 Distortion Trim
Always get this done if a signal valve has been changed.
This procedure should be carried out by qualified personnel only.
Procedure:
- Connect generator to input of compressor.
- Connect Analyzer or distortion meter to output.
- Ensure the compressor has warmed up for at least five minutes.
- Set generator for 1 Khz and +4dBm output.
- Set Threshold to 5.
- Set Attack to ‘Fast’, Release to ‘Slow’.
- Adjust Input Level control to obtain 2 dB of gain reduction.
- Ensure Stereo Link switch is in the ‘up’ position ( no linking).
- Adjust the presets with a trimming tool or instrument screwdriver
- shaft which are inside the hole in the black plastic nuts (one for
- each channel) located on the valve deck, for minimum distortion.
Note: If using an analyzer which displays harmonic analysis adjust for minimum odd order distortion.
