Problem solved in two stages!
1st: After a chat this mornig with Holger, he advised me to check my grounding.
And he was (as always *g) right. I had a seriuos grounding issue on PSU PCB. After i fixed my star grounding the hiss/buzz was gone as described last night.
2nd: Now i suffered the same buzz problems that Ian, Pierre and Holger had in the past. As mentioned i put an existing 220nF accross the HT-0V entry on the Mixer PCB.
Both problems solved now and it was a big load off my mind, because i expected a total wrong setup/build which comes with big self doubts if i'am ready for the "EZ-Tube-Road".
There is a next problem at the horizon which i need to investigate further, because i believe to hear a low frequency rolloff in "Line" mode in comparison to the "Mic" (with pad activated and gain adjusted) for the same output levels.
For now it's coffee time and finally starting the REDD & Pultec EQ Boards.
Cheers, Sven
Cheers, Sven
