I have been asked what is the tube complement for this design. The answer is:
I have tried to use tubes that are readily available. Each PCB uses a pair of 6922 and a single 12AX7 tubes. The PCB houses two complete amplifier stages that each use a single 6922 and half the 12AX7. Each amplifier can have its gain varied from 6dB to 40dB by altering a single resistor. One stage is tracked to the input transformer and switches (gain, phantom, pad, phase and mic/line). The other stage is used for gain make up after the external fader and separate passive EQ and has a pre-set pot to set the gain.
The 6922 tubes I have had best results with are JJ E88CC ( a 6922) and Electro Harmonix 6922EH. Both are in current production but the NOS Russian 6N23 also performs just as well. Please note that you cannot use a 6DJ8 (ECC88) instead of a 6922 because the 6DJ8 does not have a high enough plate voltage spec. For the 12AX7 I use a Sovtek 12AX7LPS because it has the lowest distortion of any 12AX7 type I have measured but you can use pretty much use any 12AX7 or ECC83.
I am in the process of drawing schematics and will post them soon. In the meantime here is a pic of what I hope will be the final PCB layout.
