buildafriend said:dude Helios 69 type EQ's lined up after vintage style tube pres channel after chanel.. AWESOME!!
I would love to hear a mix that was entirely done through this console with a small variety of industry standard mics.. But thats probably asking a lot..
I think the coolest thing about the EZ Tube Mixer is it is modular both at a mechanical and an electrical level. The EQ boards are separate so you can use them any where - channels, groups, on their own for mastering, with tubes or with solid state.
The tube mic channel PCB also doubles up as a a pair of mix bus amps. The tube mic pre can be made into a stand alone module with EQ with transformer balanced in and out or it can be used as a channel in a mixer with a separate routing module and channel fader. You can build a mic amp in a 3U high module or with EQ in a 6U high module.
That was the idea anyway!
