Adding info/discussion to an old thread here, rather than start a disjointed new one...
Have any of you actually measured/analyzed the attack and release times on the AM864 circuit? I have one on the bench currently and I simply cannot justify fitting the attack pot to my front panel, as it simply does damn-all!
I have tried so many different values, pre-charge/attack caps or whatever you wanna call it, and the sidechain seems to just not want to have a controlled attack. Or at least not controllable with any perceivable change.
Right now I have 22K for R11, followed by a 50K pot for attack, then instead of R1 I have a 150K resistor with 2M pot in series. This 2M pot gives me decent control over release time.
I see that the Nu-Federal PCB/Design uses 22K for R11, 25K release pot, and R1 is made up of 1M pot plus 1M resistor in series. This is all well and good but I have yet to find any evidence of actual attack and release times... Are we all just fitting this attack pot for the sake of it? Hmmm
- The manual states that the 6SK7 screens sit at 118Vdc. To my eyes it looks like they should be at 12.5Vdc (which seems unusually low), coming from that simple PSU voltage divider/bleeder made up of R6 and R8. What is going on here?
Bit late quoting this now Matt C but why not I guess... Yes I also noticed this 118V versus the low V in the actual circuit. My assumption was that it was a typo, missing a decimal point and should have been 11.8V in the manual. This is an extremely low Screen voltage compared to say the BA-6A which uses same tubes, but then the plate loads in the federal are lower at 12K compared to about 22K in the BA-6A. BA-6A has reg.150V thru 5K to screens. Maybe this is just what gives the federal it's sound??
Similarly, the grids of the 6SK7 sections are listed as sitting at -1.3Vdc. Is this another case of grid leak bias? or is the diode section of the 6SQ7 conducting just a little bit while idle?
Yes, well mine are measuring just -800mV, with and without the 6SQ7 fitted in fact. And in order to completely turn off G.R. in mine I need to apply a set minus voltage to the sidechain, otherwise the 6SK7's still drop their conduction and compress with high level input. and that is with AND without 6SQ7 fitted! But with the set bias voltage she distorts suuuuuper nicely!
