Rob Flinn
What is 12 x 12 grilling, if you can explain it to me I can measure my head basket for you to check ?
Rob Flinn said:Hi chunger.
I'm looking at your assembled mic pcb's & am wondering if the whole assembly would fit inside a 38mm inside diameter tube ? From your previous posting I can see that the width of the board is about 38 mm. but with the semi circular board attached it looks like the whole assembly needs a wider tube than the 38mm that the original is. COuld you confimr either way ? The reason being that your boards could be a neat solution for my build using original metalwork, but I suspect it may be a bit too big.
micaddict said:I'm already on Tim's list for a "standard" CT12. What to do now? :-\
OK, seriously now. I believe Tim himself (but I can't speak for him) prefers the full air and detail of the original, although those likely varied, too. From what I recall (but again, don't take my word for it) Jim Jacobsen asks Tim to "tame" the capsules a little in the highs, for his (C12 inspired) Dutch microphone.
Still, such (a) large membrane(s) without the center screw will always sound somewhat scooped, albeit in a broad an smooth way.
You could try to compensate right at the beginning i.e. at the capsule, but there's only so much you can do there. Also, I'm not sure if that's a wise thing to do. More about this later.
Micaddict, could you expand on this? I haven't seen anyone say Tim Campbell's capsule for this project would be different from his standard CT12. Did I miss something?
And here's the thread:The recent batch of capsules that Tim sent me has a little more bass and is slightly warmer then some of his other capsules. The capsules he sent were a copy of a particular CK12 capsule that was warmer. I like the way that he can tune the capsules for different applications.
If all goes well with the stock options, I'm inclined to keep them that way and assume that Tim and Oliver both have made significant efforts to keep their products as close as possible to the middle-of-the-road original configurations.
I was also lucky that AES is in town this weekend, so I had a chance to speak with Oliver Archut from Tab Funkenwerk at length regarding T-14 transformers and he is amicable to sourcing these to me for this project. He suggested 3 variants of his T-14 for me to try and gave some insight into optimizing to Tim Campbell's CT12 capsule.
Oliver knows this capsule well and recommends a custom winding on the T-14 to optimize for the bass and treble footprint of Tim's CT12.
Ah yes, I remember the post. I've read probably every JJ Audio post on the forum haha. But actually, while I know Jim Jacobsen said he was going to get Tim to tune the capsule specifically to the Dutch, I didn't take that particular post you quoted to describe the tuning for the Dutch. I thought Jim was simply saying that Tim's capsules vary in tone and the ones he was referring to happened to be warmer, but not that he uses a darker capsule in his Dutch now. I would probably request a "standard" (middle of the road?) CT12 if I was in the market right now. I know Blackspade also has the CT12 tuned to sound more like a 251 in the UM25C. It's very cool to have options.micaddict said:Micaddict, could you expand on this? I haven't seen anyone say Tim Campbell's capsule for this project would be different from his standard CT12. Did I miss something?
I only meant to say there could be a choice there (like there seems to be with the T14).
It had been a while since I read Jim Jacobsen's comments on the Campbell capsules he uses for the Dutch. Hence my disclaimer in the same post.
I did a little search and found one of the relevant Gearslutz threads form 2010. If need be, I might be able to find more.
Anyway, here's a quote:
http://www.gearslutz.com/board/gear-shoot-outs-sound-file-comparisons-audio-tests/537741-apex-460-vs-dutch.html
micaddict said:If all goes well with the stock options, I'm inclined to keep them that way and assume that Tim and Oliver both have made significant efforts to keep their products as close as possible to the middle-of-the-road original configurations.
Yes, that seems to be a wise thing to do, in any case at this point.
And hey, it's your (and Matador's) show.
BTW, I only started my ravings as a reaction on what you said in reply #30:
Melodeath00 said:...so it's kind of funny the transformer can be "tuned" to this specific capsule.
Matador said:However as usual, Chunger's detailed drawings left nothing up to interpretation and all 4 mounting holes lined up exactly!
