Well done. Very neat build. Is it OK if I pass the pics to Pierre who keeps an independent gallery of builds based on my designs?
Hi Ian,
so in practice, just feed a hotter signal into the box for more colour.
I am not sure which page 13 you are referring to. Can you please clarify?The attenuator; I assume that would be a dual gang 1K LOG pot like depicted on page 13, but instead of using it as a pad on the input transformer, it would be connected in the same way on the output transformer? The schematic on page 13 also shows resistor R3 of 68 Ohm, would an additional resistor also be necessary in this application? If so, what value would be best?
Cheers, Alex
Thank you for the explanation Ian, and apologies; I could have been clearer with my question.Yes, that is right
Edit: I just realised which page 13 you are referring to - the build instructions. Page 13 show a variable mic input pad whereas what you need is a variable output pad. Two versions of a suitable circuit are shown on page 23 but these days I just use a straightforward 1K LOG pot wired across the output transformer secondary.
That is exactly what it is there for.Thank you for the explanation Ian, and apologies; I could have been clearer with my question.
The output pad on page 23 of the build manual looks simple enough, it's just a dual gang LOG pot. Since this pot attenuates the balanced signal I assume this one comes after the output transformer, thus giving the option of running the entire unit hotter including both transformers? If so, it keeps getting better and better.
I don't sell many PCBs these days so unfortunately I rarely update that section of the web page. As you know I have open sourced a lot of them. I am pretty sure I have a few classic solo PCBs in stock.I haven't been able to find the PCB files for the Classic Solo Lo Hum on your site, and the PCB shows on stock even though the page says that the table was last updates in may 2021. Does this mean I can buy one from you? If so I will send you an email, as instructed on the page.
Cheers, Alex
I saw you open sourced many projects, much respect for that! I guess the Classic Solo is not one of them (yet). Nevertheless I'd love to support your work by buying a PCB from you. I'll send you an email to work out the details.I don't sell many PCBs these days so unfortunately I rarely update that section of the web page. As you know I have open sourced a lot of them. I am pretty sure I have a few classic solo PCBs in stock.
So far the only amplifier I have open sourced is the PMTGMU. The others will be eventually but not just yetI saw you open sourced many projects, much respect for that! I guess the Classic Solo is not one of them (yet). Nevertheless I'd love to support your work by buying a PCB from you. I'll send you an email to work out the details.
That would be both interesting and useful.I also saw that there is some pretty decent build documentation for the latest revision of the Pultec EQ. When I get to this build (it is next on my ToStart list, however I have some projects on my ToFinish list so it might take a couple of months) I will make an effort to document the application of the Classic Solo PCB in SRPP configuration as a tube gain makeup for the Pultec EQ and share it here.
It is not about tolerances. I use two 33K/2W resistors in series to manage the expected heat dissipation. If the HT voltage is 300V, the total 88K string (66+22) dissipates over 1 watt of heat and three quarters of that will be in the 66K so I split that heat over two equal valued resistors. If you want to use a single 68K then I would suggest it is rated at 4W or higher.I have also compiled a BOM for this project with parts that are currently available from Mouser.
Regarding the BOM of small parts, I have one more question: you opted to put two 33K 2 Watt resistors in series. I guess a 66K resistor is not a common value, but the 33K part from the original Farnell BOM has a 5% tolerance, thus putting 2 in series could in practice yield a total resistance anywhere from 66.7K to 69,3K. 68K is a common resistor value and available in 2 Watt 1% tolerance, that would provide a single resistor with a value between 67,32K and 68,68K, within the tolerance of the 66K 5% solution. Is it really this simple and can a 68K 1% resistor be used at this point, or is this part more critical and am I missing something?
Cheers, Alex
Hi Ian,It is not about tolerances. I use two 33K/2W resistors in series to manage the expected heat dissipation. If the HT voltage is 300V, the total 88K string (66+22) dissipates over 1 watt of heat and three quarters of that will be in the 66K so I split that heat over two equal valued resistors. If you want to use a single 68K then I would suggest it is rated at 4W or higher.
Hi Ian,
parts order expected to arrive early next week and can't wait to start building. I have started populating the PCB with what I had on stock, mostly the common resistors and I also ordered some tube sockets which I was able to fit on the board after bending the pins. The 6922 in the sockets should still fit (albeit snugly) in a 2U rack enclosure.
The wire bridge between P1-P3 and P2-P4 I did with wire that fit the holes on the PCB, which is 24AWG I think. Since it's coming off the HT rail I would rather have used thicker wire but I could not get the thicker wire through the hole. I then assumed is must have been designed for 24AWG but I am still hesitant; is it thick enough?
Regarding R23, I read the tread back another time and saw this question had actually already been asked and answered before. In that particular post you mention that if one chooses to use a 68K 5W resistor, it needs to be given enough spare to radiate its heat. Does that imply that putting it flat on the PCB is not a good idea?
I think bending the pins so the resistor is elevated is the best solution. You could add some insulated sleeving if you are really worried about exposed HT.I ordered a 5W resistor but it's slightly longer than what the lead spacing on the PCB allows for. I can either bend the pins so it is elevated a bit off the board, or I can solder the south leg of R22 through the north hole of R23 and the north leg of R23 through the south hole of R22 and put R23 flat on the PCB - those legs are connected on the bottom side of the PCB and it shouldn't become too much of a kludge that way. I think flat looks neater and I'm not a fan of exposed HT leads.
I noticed this in the build docs but I was being pigheaded about using socketsThe PCB is designed to take 1mm gold pins for the tube sockets. I just realised the pins are listed in the BOM but not mentioned in the text.
I guess since this project runs on HT one should be extra careful anyway when working in the guts of the machine. As soon as I receive all the parts I'll do some creative lead bending and take a few more pictures.Yes, flat on the PCB is not a good idea. I think bending the pins so the resistor is elevated is the best solution. You could add some insulated sleeving if you are really worried about exposed HT.
