ding said:
I think I'm just going to build out the extra HT. it's not like it's going to break the bank. Probably just use one 48v supply though.
That would simplify things a lot. It avoids possible ground loop problems. With two HT supplies you just wire the AGND of each one direct to the chassis bolt. One word of warning. If you are sharing AC heaters, which it seems sensible to do, you could end up with two heater elevation circuits fighting each other.It should not really be a problem but just to be on the safe side you should fit the heater elevation components only to one of the HT supplies. On the other hand, if you manage to get hold of a mains transformer with two separate AC heater windings, and there are plenty of them about, you can build both HT supplies as normal and just wire AC heater windings,the PCB to separate windings.
