G-Sun said:
I don't quite understand this yet.
And both eq gain adjust (+-pot)
or fixed gain switch
seems not so important.
(at least if the extra gain is just adding noise)
So I'll just wait a little to see if you implement any recommendations and revisions regarding this.
You need to understand a bit more about gain and noise. Usually, the overall noise performance of a mic pre is determined by the first amplifier stage. It can usually be specified by an equivalent noise level at the input called EIN (equivalent input noise). This is the parameter most mic pre manufacturers like to quote. Now, there is no such thing as a noise free amplifier but many come pretty close. EIN is usually specified with a 150 ohm resistor connected across the input since this is the typical source resistance of microphones.. The 150 ohm resistor itself generates noise due simply to its temperature and at room temperature in a 20KHz bandwidth, the noise from a 150 ohm resistor is about -131dBu.
So, suppose we have a perfect mic pre with 80dB of gain connected to a ribbon mic with a source impedance of 150 ohms. Just like the signal, the input noise will be amplified by 80dB so at the output it will be -131 + 80 = -51dBu. It can never be any better than this - it is just physics and there is no getting away form it. Of course, most mic pres are not perfect but the best will only add a dB of so of noise so they come pretty close to perfection.
There are several ways of measuring EIN - you can use an average detector, an rms detector or a quasi peak detector. You can weight the frequency spectrum - A weighting is common but there is also an IEC standard weighting for noise measurements (the idea of both of these is to mirror the frequency response of the ear). As you might expect, the different methods and weightings give different values for EIN. There can be as much as 8dB difference between the different measurements of the same mic pre. The average detector and A weighting tend to give the lowest figures so I bet you can guess which ones the marketing guys like to use. Sometimes these even give figures better than the theoretical noise of the resistor!! - just look at the figures claimed for the THAT mic pre chips.
My mic pres are not perfect and I use the IEC standard weighting and a quasi peak detector to measure EIN which tends to give the worst results of all. My mic pres generally measure better than -120dBu using this method. Using A weighting and an average detector they could be as low as -128dBu. Certainly, people who have used ribbon mics with them have said how quiet they are.
The bottom line is that if you need 80dB of gain, your output noise is going to be somewhere between -40dBu and -50dBu. Assuming the first stage is pretty good, then the noise from later stages will make no difference - they just amplify the signal and the already existing noise.
