CJ
this was purchased as a direct replacement for a DIY princeton reverb amp
it goes pri-sec-pri
1500 turns of #36
95 turns of heavy stuff,
1500 turns of #34
turns ratio is 32:1, Z ratio is 8K to 8 ohms,
done on a square stack of EI 625, 29M6 steel, laced 1 x 1, no shields,
215 calculated henries pri, and we hit 18.4 k gauss at 26 hertz, not bad, this is a guitar amp, which is mostly mid-range, Fender might even tune the speaker cab with the transformer,
dcr is balanced by using 2 wire sizes for the pri, so 6v6gt tubes run balanced and core does not freak out from dc cause by imbalance, 147 ohms each for 294 total,
sec is about 0.5 ohms
it scoped out real fine, 5 hz to at least 60 k hz pretty flat,
so we decided to investigate... ;D
it goes pri-sec-pri
1500 turns of #36
1500 turns of #34
