Lot of gear got modified to fix the pin 1 issue back then. Some studios were cabled for balanced gear so the patchbays and equipment runs had the screen grounded at the input of any device only and screen ground lifted at the output end of any chain (except for mic inputs).
I’ve always treated patchbays as an extension to the console and left the grounds separately wired at each patch point, not common bus grounded at the patchbay which can cause problems, but some outboard gear would have the output grounds lifted in the hard wiring if needed.
(There were also schools of thought the opposite way - lifting input grounds and leaving output grounds connected - not sure how well this would work)
