Freddy G said:
That's the thing. These mics have never sounded that clean. Actually kind of 'creamy' especially in the top end. I often have a problem with singers....dirty "esses"
This what you can find on schematic i posted should solve your problems.
Freddy G said:
Thanks for this info! That's quite a lot of changes to the schematic. Even the output cap is very small. Can you explain the thoughts behind these changes?
Most important change is input topology.
I prefer much more M49 option than C12 option. Also capacitor between both diaphragms 1nF is enough. You could also test lower values from 470pF - 1nF. For cardioid best option is disconnected back diaphragm (or 1nF cap) but for this you will need to install switch or relay.
EF86 doesn't work great with 1G at the grid - test lower values in original circuit and you should notice difference. 80V (actually 75V or so) will work for most M7 capsules, but dfinately going below 70V you should notice also change not only in sensitivity.
Polarisation voltages also could be better matched. Depending on biasing and drop of the plate voltage, main polarisation voltage is changing from let say 70-80V, where the back diaphragm polarisation voltage is always around 80V (for cardioid setup - fig.8 160V).
Output cap? I didn't measured it for lundahl transformer - but with other 6.5:1, 0.5uF-3.3uF will give you flat response to 20Hz.
Try 0.5uF, for example paper cap, you should like it. I wouldn't go higher than 1uF at this position. Strongly recommend use 4.7k trimpot, instead 1.6k resistor, to set the bias.
You have two microphones, so i recommend you to try each option in comparison to original circuit. Step by step. You should be able to judge easily what makes changes. I would start from input topology, change polarisation voltage, high z resistors, then biasing and at the end for example output cap.
BTW. Use definatley biasing scheme as it is on my version schematic. Mixed option as on original schematic with extra trimpot was for "test" features. Definataly no applying any feedback which have any specific feature makes it useless. You could even start with replacing 220ohm resistor with jumper and here for the start you should hear the difference.
