Freddy G said:Hi In76d,
I got around to testing some mods. The headbasket test proved to be very subtle. So I don't think that's a problem.
The output cap got switched out to 1uf (I know you recommended 0.5uf, but 1uf was all I had at hand) and it definitely reduced the low end. Then I removed the 220r resistor and replaced with a jumper. Then installed a 4k7 trimpot and tested various bias settings.
Everything was going along well until I modified the section near the capsule. The two 1 gig resistors swapped for 100Meg, the removal of the 1n cap between the one of the 100M resistors and the center of the capsule. The swap of 1n, 10n capacitors and all the rest as shown in red on the mod scheme. Now I get very low gain and bad sound. I've checked and double checked and I can't see any error I made. Not sure what to do now!
By the way, here are some A-B test files if you care to listen.
Unmodded G7: https://app.box.com/s/9zf237xy2h3ibpz3jp132aw2l32e9sho
1uf output cap: https://app.box.com/s/s2ypnihcav8wll8prdrf7w4rra53uq9q
220r jumpered: https://app.box.com/s/riq2gjex996mj3hi9ak0e3421ij72w1y
2.7k bias : https://app.box.com/s/t59bd3itg1gp00vbcb84yamv8hrymd5f
2k bias: https://app.box.com/s/felx41e8rkp77f63x3n2i082ya5ok0ou
4.7k bias: https://app.box.com/s/cjcp29lq732di57wxk1glv65n8y8rq39
700r bias: https://app.box.com/s/jnlrafbuqgdhi6c5b71fgdv62ag92f5t
input mods: https://app.box.com/s/okbg1zy3711ux5dzikxcqux53h1n4h4n
And just for reference, this is the other unmodded G7 from a recording session today. It's on the ukelele and also the vocal. No EQ on the vocal, just compression and reverb : https://app.box.com/s/wl2aso1a5kmc3rxrxxodlslpqkavcjfn
First question Did you adjusted microphone preamp gain after each step?
Second question - related last step - input topology - are you sure, that you made proper connection - didn't you left grounded front diaphragm? You can expect lower sensitivity, but 2-3dB is max. What is that hum and noise? Is it high microphone preamp gain or faulty connection?
