Well, if you want a parametric with sliders, Orban made a Paragraphic. Model 672 I think...
There is also a LOMO one, but it does not have Q.
JohnRoberts said:One of my more successful patents while working at Peavey [US05737428 Roberts] (and subsequently copied by Behringer with their own patent), was FLS "feedback locating system" the illuminated LEDs above one GEQ slider with the loudest bandpass.
This was a quick and easy aid for reducing feedback, or finding proper frequency band to EQ.
Whoops said:R2D2 if you want to build a graphic EQ for the fun, go for it, but really think that John is right, it's an obsolete unit.
I'm a professional Mixing Engineer, both Live and Studio.
In Live contexts I don't use a Graphic EQ for more than 10 years, analog consoles are no longer used in live sound and Digital consoles have 4 or more bands parametrics in every channel, and sometimes 6 bands parametrics in the outputs. You have also Graphic EQ inside the console if you want to use them.
So basically theres a lot of options for Graphic EQ's in the used market nowadays and you can have them for really cheap.
Sometimes even for free from a local Church, Bar, or PA company
I also agree with PRR that having separate faders from L and R is better
just my 2 cents
This is a comment I often hear; however, as much as the use of a GEQ did not necessarily imply complementing it with an RTA, it seems to me a parametric as system EQ should be used only in conjunction with a high-rez analyser.Whoops said:In Live contexts I don't use a Graphic EQ for more than 10 years, analog consoles are no longer used in live sound and Digital consoles have 4 or more bands parametrics in every channel, and sometimes 6 bands parametrics in the outputs.
abbey road d enfer said:Today any smartphone offers measurement facilities that were a lab curio just a few decades ago.
Rob Flinn said:Some of the DN27's I've had are transformer coupled. All of them have holes on the back panel to mount Sowter transformers. Although I think this was an optional extra. Some also have a relay circuit so that if the power supply blows they revrt to bypass to keep the show going. Not quite sure how pleasant this would be if the GEQ was set to notch out some serious feedback.....
Oh thats interesting John , I didnt know that was one of yours ,
I used a few Peavey and Behringer mixers with it built in ,but never found the need to engage it . For a small band that dont have a sound engineer or in a room with bad acoustics FLS works well I think . I found with practice in a live situation I would instinctively know which band on the graphic to reach for when I heard the feedback note ,its almost always the lead singers fault in any case ;D so you nip in and notch his stage monitor .
I'd keep a 58 up at the desk with me for monitor talkback , handy at sound check , and ocassionally during a performance if things were getting out of hand onstage ,if the band were really good Id gently tap on mic at the encore in time with the applause and send it out front of house just to get the air moving in the room a bit more , neither the crowd or the band are even aware of the sonic shockwaves ,if you have lots of low end headroom you can punch em right in the junk ,there carried away with anticipation, their bits are wobbling all over the place and the band explodes onto stage , there wouldnt be a dry eye or panties left in the house .
I think we had a discussion on graphics before and the general concensus was a proper inductor based unit wins most of the time . Sometimes Ive found 31 band graphics usefull on bass , for cutting low end honk and making each note appear at the same volume , .I get by on basic console 4 band eq for almost everything ,
I think an inductor based graphic for messing sounds up is a good plan , with misuse you can probably coax some interesting harmonics out of the inductors.
Im liking the look of the DN27, similar but with Transformer coupled ins and outs . bound to be loads of them knocking around from old Pa systems.
