scondon
Active member
Well, I made the J8 pin mistake and was rewarded with a long ribbon of smoke out of Q13 on one of the boards. Fun! After fixing the J8 connector, the board passes signal, but it's slightly distorted. There's a layer of crackly distortion on top. The other board sounds fine. Next time I will triple check before applying voltages. Following the lead of Madriaanse way back in 2007 (!) I think I'll replace Q12/13.
EDIT: I wound up just replacing Q13. I went down to my local electronics store and found NTE123AP as a recommended replacement. I replaced the part, the crackle is gone and after measuring offset I'm almost done. After I replace R46 and label the front panel I'll finally be able to get down to using it.
