Matador
Here are preliminary completed layouts.
Top of PCB:
Back of PCB:
Top of PCB:
![grmp2_layout_v2_top.jpg](https://proxy.imagearchive.com/98b/98b304ac0801f318cdc9c3504c19fb4f.jpg)
Back of PCB:
![grmp2_layout_v2_bottom.jpg](https://proxy.imagearchive.com/be1/be1e22c3dd37604fb12c173de51fdc7b.jpg)
Ptownkid said:What lead pitch are the connectors?
If there is enough demand (and this board sounds fine and works) I would be happy to copy it to a 51X template. However keep in mind I don't have neither any 51X gear to confirm the design, nor capabilities to make or design front plates so someone else would have to do that.
Ptownkid said:Is it possible to make it 2.54mm?
pachi2007 said:+1 for the 51X layout.
Awesome work Matador!
okgb said:Where the opamp ? although simple , the 1/4" d.i. input does work well , I'd put in at the bottom though
so the cable doesn't dangle over the switches and cover them up . there's an l.e.d. for phantom power ?
3nity said:Matador looks really impressive Tio.
It looks like the board is less congestionned.
Did you thought about a doing a version for Lorlins and not GRayhills??
I mean with a daughter board for lorlin and toggle switches for 48/pad/pol??
This would make the project more affordable and still be quiet fancy.
just my .002 cents.
