Green Pres Finished...almost
pxpx83
Active member
Orlando, FL
Finally finished up my pair of green pres. Tested them with an sm57 earlier today, and they sounded great. Everything works perfectly except for the led meter. I get a steady glow on 2 of the green leds on ch. 1 and both green and yellow on ch. 2. This does not change with the input signal (i.e. no input signal still shows lit leds). Any ideas on things to check? I'm not sure I connected the jumper correctly to make the led monitor input gain. Thanks Peter for a great project and Ptownkid for the parts kit.
pxpx83
Active member
Orlando, FL
Is this the correct spot for the input metering jumper? I'm still troubleshooting my led metering problem.
fucanay
Hayward, CA
Check out this pdf.
http://www.nrgrecording.de/green_pre.pdf
This will show you the correct place to wire it to.
Matt
pxpx83
Active member
Orlando, FL
Ok. So the jumper is right on both preamps, and I still cant find out what the problem is with the meters. Adjusting the meter trimpot has no effect and even without signal present, the same leds stay lit. Here is what I am seeing:
ch 1.
green -10.93
green -12.89
yellow -14.83
red -14.97
ch 2.
green -9.06
green -11.02
yellow -12.96
red -14.83
Does anyone have voltages for the TLO72 and LM339? I'm gonna pull both preamps out of the box tomorrow, and recheck component placements and orientation.
Thanks.
-Mike
