moltenwok
All good Martin, like a good cheese these things take time to mature, thank you so much for your massive efforts to the DIY community
JMarcovis said:No worries Martin, thanks for the heads up. Can someone post a link to the FB group? I'd like to join. Thanks!
moltenwok said:Hi guys, meters and shields were posted out on 31 May. Please let me know when they arrive so I can stop worrying about the post. So far its cost me over 300 to help you all out, so I hope they all arrive. Cheers
rainton said:Good news everyone!!
The chassis are powder coated and on the way here.
Also the front panels are silk screened and and should be here Monday or Tuesday!
I haven't seen neither yet, but I was told they all came out pretty nicely! I can tell you more once I have them here.
Livingnote is about to finish the handmade pcbs and he told me I should have them in the mail later this week.
The turret boards are CNC'd and they should arrive later this week as well.
The only thing left to do now for me is adding the fork turrets to all pcbs & turret boards...
This will take me a couple of days once I have the boards, since it's roughly 50 turrets per kit!!
But we're getting closer now![]()
Martin
jslstudio said:I think Martin said he would have hidden counter sunk?
Under the faceplate......But most real ones have threaded shafts.........
J
rainton said:No hidden countersunk holes - sorry.
But it shouldn’t be a problem to drill two little holes into the chassis front-panel to be hidden underneath the black faceplate.
The only thing though:
The faceplate is held in place by all the nuts used to mount the pots & switches on the front.
In the above mentioned case two rather important nuts would be missing.
Potato Cakes said:All the Langevin ones seem to have the threaded shaft, but the Daven 600/600 ones I've found so far do not seem to be. I'm also bad at the Internet.
Another question I have regarding the Daven stepped attenuators is that I have found some with different dB ratings but are still 600 ohm. What is the gain range for the input and output needed for the UA 176?
Paul
I went a bit OCD trying to find the exact attenuators for this - Martin you really scored to get the originals for such an amazing price.rainton said:The original ones are 40db with 2db steps - 20steps
The ones you posted have 5db steps - a little bit difficult to adjust the comp with 5db steps
The original was 2db steps with additional “vernier” pots on input and output for fine tuning
Phrazemaster said:I went a bit OCD trying to find the exact attenuators for this - Martin you really scored to get the originals for such an amazing price.
As far as "original" specs this is what I dug up, along with related similar parts:
Daven:
• LA-353-G: Actual Part used as per rainton in previous thread here - 600/600 Ladder, 20 steps, detents, 40DB reduction, threaded bushing mount
• T-257-G: 20 steps, 2DB/Step, 600/600, "T", no taper, 40DB total, Detents
• T-320-G: 20 steps, 2DB/Step, 600/600, "T", no taper, 40DB, Detents, last step infinity
• T-520-G: 20 steps, 2DB/Step, 600/600, "T" - 1% precision
• P-350: 2DB/Step, Infinite, Linear
• P-354: 2DB/Step, Infinite, Tapered
Langevin:
• RMX-601: "T" 20 step 2DB/Step, 1-gang, infinity cutoff
• RMX-601-2: "T" 20 step 2DB/Step, 2-gang, infinity cutoff
• RMX-601-3: "T" 20 step 2DB/Step, 3-gang, infinity cutoff
• RAT-631: 20 steps, 40DB, 2DB/Step, linear, no infinity, detented positions, Unbalanced Ladder
• RAT-633: same as above, Balanced Ladder
• RAT-601: same as above, Bridged "T"
After many, many months of hunting the snipe - the elusive LA-353-G, Daven 600R 2db stepped 40db total attenuator complete with bushing threads, or a corresponding Langevin, I gave up and contacted Shallco directly and had them custom made. I'm not going to tell you how much that cost.
Looking forward to (eventually) doing this project. Great job Rainton!!!
Mike
