What beatnik wrote regarding the attack pot.
Also available at Banzaimusic.com:
https://www.banzaimusic.com/Alpha-24-SPDT-25k-lin.html
The schematic calls for a DPST switch (which is exactly the one kosi posted the link to) - but the way it's wired you can also use an SPDT and the Alpha has a nice feel and does the job well!
Regarding the power transformer - I welcome the discussion
Following several 175b or 176 projects, they all used the Hammond 370BX - which is the same one as suggested for the Pultecs.
Drip Electronics recommends it for their 175b pcb version and another builder here successfully used it for his 176 build a couple of years ago.
I tried that transformer for my prototype and it works.
I have to admit though - I had the primaries wired up for 240V use first (even though we have mostly more like 220-230V here) and ended up being rather on the low side voltage wise. I rewired the primaries for 220V and am now still a little low but within 6% of specs - so that's not too bad
Even though I can say the transformer gets rather hot after a couple of hours of use. I'd say like 50°-55° celsius.
The problem is, space is at a premium at the back of the unit. On the right side (viewed from the back) we're completely depending on the pcbs, since many components that stick out the back are soldered straight to the pcbs. So the layout is predefined.
And to the left of the output transformer the space is extremely tight. I could try to get maybe 8-10mm more to mount a larger transformer but I'm not sure yet if it's possible.
The size of the 370BX make it fit perfectly.
Choke can either be Hammond 158M or Triad C-7X.
In terms of the "low budget" UTC iron: I think emrr's posts say it pretty well.
When I'm committing to the quest in recreating the iconic vintage gear I want to go for it's original signature sound. I want to find out what exactly it is why people love the sound of a particular unit.
That certain sound character was, what I experienced many times in the past when I finished an authentic replication, instantly sounded familiar in some way - most likely due to having it heard on countless records?
What I can say in regards of the 176 - I used UTC-01 and UTC-A19 together with a Sowter output transformer - and my 176 indeed sounds very special compared to other pieces of gear I own - but in a very very pleasant way!! I love it
I'd love to do a shoot out with a vintage unit one day...
And YES - I will offer adapter plates
