Kingston
DaveP said:there is a measured 346V at the input to that regulator.
The toroids are rated at 50VA each so they don't work up a sweat in this amp. If the transformer has a regulation of 10% (which is good) you get 10% more voltage than the stated output.
I suspected it must be something like that, so you actually do have about 250VAC at the secondaries, which is pretty optimal. But not all transformers/manufacturers give such ample voltage "headroom" when used way below their recommended rating. I've had my share of bad luck in this area and tend to always over-specify generously.
