GssL 20th Anniversary edition
No problem Gustav, I removed the files. I leave the rest with the builders. Once I have more information on the color module implementation, I'll chime in. Thanks!
Like I said, I dont mind you curating it, if you want!?
You can even just do the BOMs, and post the links. I will happily replace the links in the first post - I just dont want to go over excell sheets and do the work with your approach, cuz I find, that most times, something pops up for a correction with real-world experience anyway. At this stage, thats what I would rely on rather than rechecking lists more times.
Gustav
I’m playing around in FrontDesign a little. Have been in contact whit Modushop and must say that Gianluca is really helpful and seems to be a great guy. Any questions or doubts just send him an email.
  • panel_20th_VU_S500_Andado.pdf
    36.1 KB
And you can always leave it out or put something else in there. I have seen, you can buy vero-boards in the format to clip on.
Below it stands a little more finished.
I need to change out the scale on the meter, and I dont have any colour modules to do that final test with yet before signing off on the project completely. It will work, its such a simple part, but you just never know if theres something that will warrent a small change to the Gerber.
Knobs I used are from Sibalco.
Remember, guys. This is DIY, so you dont have to ask me for a different scale or design or adding power switches.
Im happy with the design I did, and I did it mostly to share a panel with the standard values.
Just do you own!
Gustav
Just do you own!
Gustav
Hi Gustav. What size is those knobs and where did you buy them? I want some BIG knobs to :D
Think I'm pretty much done whit my front panel. I attached the fpd file if anyone want it as a base to adjust further.
  • panel_20th_VU_S500_Andado_V2.pdf
    37.9 KB
  • panel_20th_VU_S500_Andado_V2.fpd.zip
    6.2 KB
Great project, is it possible also to make LPF. Soms in dance music you wil not to compress nothing above 15khz. Then you can compress to the taste of freq spectrum reference. This thing wil be the also good and flexible as mastering compressor.
