GssL 20th Anniversary edition
This is how it’s connected and whit 2k resistor on +
Red to + marking on meter
Black to - marking on meter
You seem to have it hooked up between the tests points for -12 and +12V, so thats a 24V differential.
I will make a revision note of adding a 2 way molex for an LED, but for your purposes, take it The +12VDC testpad in the PSU section, and return it to somewhere where the return current/GND nodes meet. edit:eek:f course, with the resistor in series.
Gustav
Gustav
😅 okey hope not the leds are toasted 😂 thanks 🙏
Gustav
Still the same so I guess my leds are out… but is it ok to connect like in the pictures?
I will order a new vu meter… 😅
    1.8 MB
    1.9 MB
I don't know how tricky it is to disassemble this particular meter, but typically the case is just held together by a few screws. As long as you're careful and pay attention to where things go, you should be fine. And even if you destroy it by accident, you're just back to where you started (replacing the meter), right? So nothing to lose.
As far as the LED itself, I can't imagine it's anything more special than an off-the-shelf 3 or 5mm LED. Should cost you pennies and be very easy to find.
Thanks man! Yeah you are right. I will try replace leds. And in the meantime I can still continue to finish the rest and calibrate, works whitout fancy leds
At least it starting to look like a compressor 🥰 wiring pushbuttons tomorrow and then calibrate.
    1.6 MB
