Audio signal is AC. And thanks for the pictture of the SSC filter board. Two 47Ks indeed. Follow traces.. One goes to a 22uf cap and from there to EXT (comp external SC input). And the other one ?TimKR said:
Osaki ni shitsurei shimasu.
... take your timeScript said:Audio signal is AC. And thanks for the pictture of the SSC filter board. Two 47Ks indeed. Follow traces.. One goes to a 22uf cap and from there to EXT (comp external SC input). And the other one ?
TimKR said:... take your time
The other one... IC1 PIN 1, 22uf to 47k to Return
Script said:OK, that's cos of your grounding scheme. Leave that for now. Instead, connect the black probe to the ground of the SSC board -- for instance by sticking the probe, if it fits, into the 0V of the crimp connector (on left side of board).
P.S.: If interested, for grounding the GSSL you could start read here for example: https://groupdiy.com/index.php?topic=31116.0. Question : Audio ground connected to starground, YES or NO ? -- And if connected, then only at ONE point to avoid ground loop hum).
Hi Script, thanks again for your tips and answers. Before I start the calibration, there is actually another problem that needs to be clarified. After a few weeks of using the compressor, I noticed the following errors:Seems like you have a working unitHow to calibrate the SSC filters with the trimmers is described above in this very thread twice. You might want to give it a try. It's really not that difficult.
5dB (actually 6dB on paper) build-up of sidechain signal in 'Aarhus' mode (not in 'Turbo' mode) is due to sidechain signals simply being mono'ed after leaving the filter boards. This makes the sidechain signal louder and therefore makes the unit compress more (by said 6dB). This is kind of 'normal' for Aarhus mode and observed by many builders, but it makes it impossible to directly A/B with Turbo modes, which is a real nuissance.
FIX: A possible 'fix' is at the audio input resistors to the SSC board. The how-to is actually described above, but worded differently: Those on-board input resistors want to be 10K on both boards for 'Turbo' mode, but on-board 20K on each board for 'Aarhus' mode to compensate for mono-build-up. With 20Ks at the inputs the signals are attenuated down before entering the filters, so that the mono-build-up at the '47K juntion' on the main board yields a signal loudness comparable to Turbo mode. Only then is it possible to A/B the modes at 'equal' compression amounts and really hear at the flip of a switch what the two modes really do.
HINT: (1) you have an unused relay on the second SSC filter board that could maybe be hacked to flip two signals. (2) The PCBgrinder boards come with TWO audio inputs per board for 'L' & 'R' channel signals, which are then mono'ed on-board before entering the filter section, but with two SSCfilter boards ONLY ONE input each is used. On your sketch, you use the L inputs with dark blue and light blue wires. (3) You have DC on your Turbo frontpanel switch.
I do not know the switches that you are using (you have to figure IN that out yourself), but trying to make them activate that extra relay might be worth the effort. Then that relay could be used to either (A) route the sidechain audio IN signal to either a 10K input or 20K input on the SSC board for the two modes, or (B) place a 20K resistor in parallel to an on-board 20K resistor (20K | 20K = 10K). Solution B is how I did it.
With turbo and 2xSSC filter boards you have opted to DIY a highly complex unit. You have made it this far and you are almost there...![]()
hi, have now selected everything again after loose contacts, but could not find anything. When checking out, however, I noticed that an xlr input socket is missing a contact. I mean this fourth contact, to which no cable is soldered, but which is connected to the ground pin. I noticed this because there is contact between the other 3 sockets, except for the socket on the far right. Perhaps the socket is broken or defective, so that the signal causes errors in the interface.As for the compressor, maybe, but only maybe, you have a loose cable somewhere inside the unit that connects and disconnects with vibration or whatever. I'd open the unit, run audio through it while its powered up, and poke cables with a pen to see whether audio drops out.
As for the first half of your post about your DAW, I have no idea what you are talking about.
hi, so if i understood you correctly it should look something like this right?Not an add-on
Speculating, but maybe your soundcard doesn't like your pin 1 connections (loop from soundcard through comp XLRs pins 1 back to soundcard) ? Could try connecting pin1 only on input XLRs to chassis, but not connect pin 1 on output XLRs. Make sure to search for "pin 1" in GSSL help thread and also "Pin 1 problem" on entire forum..
Also, I'd twist the input and output + and - cables from board to XLRs, if cables long enough, and definitely put shrinktube over the + and - solder joints.
That nut on the right is your safety ground ? Looks a bit flimsy. Case is properly grounded all round ? Better check. You 220V country ?
ok, now i got itOutput pins 1 not connected at all. You'd bette read up on pin 1 as well as grounding in general.
Search GSSL help thread(!) for "needle" "drop", maybe alsoHowever, I noticed the following
