Well i resoldered the wires the from MAIN to SSC PCB and now so far the unit ssems to work :
:-X
No cracking, and both sides compress the same, also the presets (60-200) do their job - i still have to adjust TM TL.
I think the description confused me a bit (see attached images):
...With the switch in the "OFF" Position the signal continues to go through the electronics but is no longer compressed... make up gain no effect... The In/Compression switch is ment and not the rotary - i thought it should be the side chain rotary :
shame on me ![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you a lot Script... i will go for TM TL now and than check the LEDs
![](https://proxy.imagearchive.com/c2d/c2d818483de167fc62faad1f67ff839c.png)
![](https://proxy.imagearchive.com/347/347b213d475742f91ced1043a22717b1.png)
