Well i resoldered the wires the from MAIN to SSC PCB and now so far the unit ssems to work : :-X
No cracking, and both sides compress the same, also the presets (60-200) do their job - i still have to adjust TM TL.
I think the description confused me a bit (see attached images):
...With the switch in the "OFF" Position the signal continues to go through the electronics but is no longer compressed... make up gain no effect... The In/Compression switch is ment and not the rotary - i thought it should be the side chain rotary : shame on me
Thank you a lot Script... i will go for TM TL now and than check the LEDs
