Hi guys,
today I´ve tried to install an expat CRC board in my GSSL and encountered some problems.
First of all here is what I did:
- built CRC board
- measured CRC resistances to correctly read 20 Ohms as Keith described in reply 72
https://groupdiy.com/index.php?topic=35641.msg718238#msg718238
- connected CRC to secondary trafo winding (center tap to center pin, the others to AC input left and right), measured DC 22V and -22V on the output pins of the CRC.
So far so good.
Then when I connect the CRC output to the GSSL power input (center to center, output at C5 to plus, output at C6 to minus, rectifier left in on GSSL board) after turning on, the needle of the GR meter pegs at the very left (negative -10 dB or so).
But when I connect a multimeter to measure DC between center and - pin, the needle goes back to 0 dB GR.
Turning around the outputs of the CRC into the GSSL board left the GR meter dark (background LEDs stayed off), and the meter climbed to a constant 12 dB GR. All this without any audio connections.
Fortunately, after removing the CRC board I could restore normal operation of the GSSL.
Does someone have an idea what could be wrong?
Do I maybe have a different version of the GSSL? My GSSL board looks a bit different as the one on the CRC promo shots (see pic attached).
Should I try with the rectifier on the mainboard removed? Of course then I would not switch around + and - to try, but connect + to + and - to -.
Thanks in advance,
Christian
