SSLtech
I'm pretty sure that Lukas used the 317/337 regulators, but that unit's on the bench at work, so it wouldn't be until tomorrow that I could confirm that.
Anyhow, yes likewise, with the CRC, the noise floor goes down so far that I measure a dynamic range well in excess of 100dB on the Expat test-mule. _Actually, I've had LM317 circuits (I use it the power supply which I designed to go with the SSL 9k for example) where they too have been noisy, and I've had to bypass the voltage sense pin with values greatly in excess of the data sheet's specified values, so I've definitely looked carefully at that side of things.
In fact somewhere here there's a thead where I was trying to trace down some noise on a 48V circuit, and it turned out to be the data-sheet implementation of the 317 which I'd made. -The 7818 which was on the same board was significantly outperforming it (by an order of magnitude, in fact!) and I knew that had to be wrong. -In the end, I was able to get them to behave similarly, but the 317 was not appreciably quieter than the 78/79 regulators when all was said and done.
Ever since then, I've been careful to measure rail noise and look at circuits' susceptibility to it.
Ah... I found the original thread: Link to the thread.
Keith
Keith
