0.5A or higher... 50V or higher... make sure it's the package type called 'WOG' (which is the button-type) and you're golden.
The 3-button controller can be made to do more or less ANYTHING. You can choose from a menu of functions, such as sidechain high-pass/flat, external sidechain, compression on/off, hardwire bypass, turbo mode on/off (Oxford/Aarhus), or pretty much anything else which you can think of. You can even fit more than one board, and have more than three buttons, if you REALLY want to go crazy! ;D
On the subject of CRC-versus off-board regulation, I've got Lukas's (most excellent, by the way!) GSSL on my test bench at the moment, right next to my test mule. The Expat test mule is actually returning slightly better numbers than Lukas's unit, although the comparison isn't QUITE 'apples-to-apples' since Lukas's unit uses pre-trimmed VCAs, and there are a couple of other things such as different capacitor and IC choices... Also, his unit draws more current due to the number of LEDs being driven, (albeit from a separately-regulated supply...)
But being in the (fairly unique) position that I can make side-by-side measurements, I can indeed confirm that the CRC-equipped GSSL produces BETTER noise-floor results than the externally-regulated version. -Don't ask me to explain it; I don't know the answer just yet, but there's about an 8dB difference in favour of the CRC in this (admittedly NON-scientific) comparison. I can post a video of the two side-by-side if anyone really wishes.
To date I've probably built about five GSSLs, including the 'Ultimate', and in addition I've trouble-shot some build problems for others (BR -Gil, Michael Pritchard -where's he been lately by the way?, and several others) as well as rescued one abandoned build, and currently taken over custodianship of Lukas's monster build... I've had varying degrees of hum problems on most of them, and in the end I've tried the following solutions:
*Adding lots of 'rail-stiffening' smoothing capacitance all over the board... Don't bother, the problem is a current-flow related modulation, which no amount of 'bolting on' of capacitance will ever solve.
*Trace cutting in various locations, with accompanying re-wiring of the ground path
*Several grounding approaches and case ground locations
*Externally regulated supply
So far the only one of the above which has worked reliably is the externally regulated supply... but then I tried the CRC and got a similar improvement, for MUCH less 'bother'. It meant the builder can still use the same tried-and-tested board, ripple is -absolutely- gone, and I personally cannot detect ANY residual hum with the CRC.
I'll double-check the test with the CRC in the expat test-mule on Monday, and compare it to Lukas' externally-regulated super-GSSL, but I recall the CRC-equipped version being quieter, for whatever reason.
Suffice to say, my continuing investigations into the GSSL as a platform (I love these things!!!) means that I'm ALWAYS looking for ways to improve them. So far I've looked into several OTHER ways to improve them which haven't panned out, and the only things which I've ever 'brought to people's attention are the things which work... and work WELL.
The bypass wiring reconfiguration to reduce distortion in bypass is one example of how I'm STILL looking for ways to improve the sound of these things. (If you haven't done this yet, TRY IT... it's free, and it's demonstrably cleaner in bypass), as well as the ultimate/turbo and VU meter GR driver developments.
Keith
