Chrome Heart
Hey all. Does anyone of a bench test for the THAT 2180LB?
That 2180b is a current in / out device. Probably the easiest way to test one is to use a breadboard to build the sample circuit in figure 2 of the datasheet. Any old opamp will probably do for functional testing. Similarly the cap values shouldn't be critical. You can feed the control voltage Ec- from a pot + a voltage divider across the supplies. Figure 7 shows how the expected gain boost/ cut is controlled by varying Ec- between -180mV and +540mV. Since the 20K feedback resistor matches the 20K input resistor, nominal voltage gain will be 0dB.Chrome Heart said:Hey all. Does anyone of a bench test for the THAT 2180LB?
wthrelfall said:Harpo, you are right - there was a short in chef's pcb, from the + to the ground just after the rectifier - a really tiny piece of copper (I took a photo in case others have this problem, it's about halfway between the rectifier and the capacitor). So thankyou Harpo & Jakob for helping...
But! I have correct voltages everywhere and I can pass signal when in bypass, but no sound when compressor is 'on'.. here we go again :-[
Harpo said:You have a short somewhere in between the positive raw DC and 0V. There are only 3 parts in this area. The (maybe broken) 1000uF cap next to the rectifier, the (maybe broken) 7815 voltage regulator and the (maybe shorted) pcb trace linking these parts. Until you remove this short circuit, you will blow your rectifier again. Use a magnifying glas to spot a short between pcb traces, double check the regulator is a 7815 for real, not a 7915 or whatever else. Ohm it out for a higher ohm reading before soldering the next rectifier on pcb. A low/zero ohm reading will indicate, there is still a short.
assuming unbalancedwthrelfall said:So, I have the compressor routed via desk inserts,
you left the cold/XLR-pin3 on GSSL output unconnected ? (you'd never be so evil to link cold/XLR-pin3+0V/XLR-pin1 on output and try to fry your NE5532)and when in bypass mode the signal is distorted, really hot.
Harpo said:assuming unbalancedwthrelfall said:So, I have the compressor routed via desk inserts,
wthrelfall said:yes, unbalanced.
yes, cold/pin 3 disconnected.
Harpo said:wthrelfall, did you already try to fix it step by step ?
http://www.groupdiy.com/index.php?topic=47.msg483540#msg483540
pin 5 set VCAs bias current with the 3K9 to the -12V rail or 5K1 to the -15V rail in between.wthrelfall said:.. except ALL 2180 pin 5's are showing just under 3V..
wthrelfall said:Harpo.
I found some bad readings using your checklist.
TL074 pin1 will measure about 0.42VAC, 0.5VAC about 0.1VAC at the junction 10K/20K/kathode 1N4148 0.8VAC, same maybe 400Hz frequency as at input, swinging positive. Case not, check for shorts, diode orientation ...
TL074 pin14 at varying ratio settings, double frequency from rectification, will measure at ratio 2:1 about 4.8VAC, 0.54VAC swinging between -3.5...-5.5V, at ratio 4:1 0.83VAC, 1.07VAC swinging between 0.3V...-1.4V and at ratio 10:1 swinging between 0.3V...-0.2V 3.03VAC . This is a DC voltage with rectified audio riding on top. Case not, check lorlin endstop position by (in this order) removing the end stop washer, located below screw and sawtoothwasher, turn the switch full ccw and put the ring back in, set for position 3.
Set ratio back to 2:1. Set Bypass switch for compressor engaged. Lorlin's endstops all correct
Checked again for shorts on both boards, none found. Diode's all correctly oriented.
All readings up to this point appeared normal.
Still looking for help...
You quoted AC measurements. What about DC? Looks like your hitting it real hard but not getting any compression. High AC voltages out of the rectification and ratio section should be causing high compression. Check further along pin 8 of the TL074 and pin 7 of the TL072.wthrelfall said:Any more ideas? I'm going to start disassembling the boards and rebuild unless anyone has a suggestion.. :-[
MeToo2 said:You quoted AC measurements. What about DC? Looks like your hitting it real hard but not getting any compression. High AC voltages out of the rectification and ratio section should be causing high compression. Check further along pin 8 of the TL074 and pin 7 of the TL072.wthrelfall said:Any more ideas? I'm going to start disassembling the boards and rebuild unless anyone has a suggestion.. :-[
Sorry for late reply. Assuming, your measurements are with VCAs pulled out and their pcb sockets pins1/8 linked. The 0.08V off will be 33K/47Ks parts tolerances.wthrelfall said:TL074 pin1 will measure about 0.42VAC, 0.5VAC
factor 8 off looks like the reason for your faulty behaviour (the rest is probably only a follow up).about 0.1VAC at the junction 10K/20K/kathode 1N4148 0.8VAC
Harpo said:Sorry for late reply. Assuming, your measurements are with VCAs pulled out and their pcb sockets pins1/8 linked. The 0.08V off will be 33K/47Ks parts tolerances.wthrelfall said:TL074 pin1 will measure about 0.42VAC, 0.5VAC
From your previous pics, parts values and orientation seem to fit, so the most likely fault might be a bad TL074 or a chips pin bent inwards, missing its connection to its socket.
Is your 'and when in bypass mode the signal is distorted, really hot' still an issue with audio-VCAs bypassed ?
