kante1603
You're welcomeguze said:Thank you so much for this, the best answer i could get.
Always learning
Udo.
Always learning
Posting some close up pics from traceside and component side around the sidechain section as well as the control board might give us a hint.wthrelfall said:Another plea for help.. my gssl is still an expensive ugly ashtray :-(
Harpo said:Posting some close up pics from traceside and component side around the sidechain section as well as the control board might give us a hint.wthrelfall said:Another plea for help.. my gssl is still an expensive ugly ashtray :-(
Reason for misbehaviour seems to be too much control voltage reaching the Ec- ports of your audio-VCAs. (what polarity and voltage is this at VCAs-pin3 with and without signal present ?) This could be caused by multiple reasons, such as shorts, wrong value or wrong orientation components, such as the tantalum caps at the release switch, or FI an opamp stage running open loop because of poor soldering or a broken pcb trace.
jjaskuna said:Alright guys, I have been doing some testing with my multimeter to try and discover why I am getting a phantom meter reading on certain ratio settings. My meter problems go away when I take out the TL074, but come back with multiple different TL074 chips. Darn. I oddly find continuity between the positive pole of my meter and my chassis ground. I am thinking this should not be and may indicate a ground short somewhere as the cause of the problem. Could someone please check and see if they have continuity between their meter's positive pole and their ground.
Jeff
Harpo said:You measured AC voltage, giving an RMS readout without polarity (and the result seems bad enough to expect both VCAs blown from exceeding the abs.max. +/-1V between pins2/3). My question was for polarity and voltage.
wthrelfall said:Oh joy! the re-built compressor is working! thanks to everyone who contributed to my cause, I will not forget you!
wthrelfall said:wthrelfall said:Oh joy! the re-built compressor is working! thanks to everyone who contributed to my cause, I will not forget you!
but my right signal is down 12db
wthrelfall said:wthrelfall said:wthrelfall said:Oh joy! the re-built compressor is working! thanks to everyone who contributed to my cause, I will not forget you!
OK, sorted.. don't know how but who cares, sounds GREAT!
ptron said:wthrelfall said:wthrelfall said:wthrelfall said:Oh joy! the re-built compressor is working! thanks to everyone who contributed to my cause, I will not forget you!
Im glad its sorted! What do you mean rebuilt? Same pcb and whole new batch of components or same pcb? just curious!
Thumbs up
