Thanks for the fast reply! It wast indeed just a wrong pair of wrong cables . So next time I will check the cables first!
??? you don't understand my questionsynnys said:12 volt goes to the control pcb
Hi Luca,Looksharp said:Hi again,
didn't notice before (too busy giggin'..) now I'm goin' to do some mix and I note that the volume of the right channel in both of my gssl finished a couple of months ago, are lower than the left channel (let's say 5 or 6 db)...this happen in "on" and bypass mode as well...
I used the 2181 vca in case it helps...
could someone please help me?
as I stated in my first post I am an inexpert and do know very little about electronics...but I finished this project without any trouble..just noticed this issue while paying more attention...
thanks!
Luca
gyraf said:Farnell also has these cheap standard types:
order no 143509 - it's 100uA, but will work with a different meter resistor (20K in stead of 2k)
Jakob E.
kante1603 said:It´s a bit strange that the issue is on both right channels.......
Udo.
Arnoid said:On the control pcb you have +M and -M but the voltage at this points are both around 11,44V is this correct
??? Shouldn't -M be a negative voltage?
As in the schematic)
M+ on control pcb is connected to the +input terminal of your current (not voltage) reading meter. This M+ is connected to gnd, as shown on schematic and when you follow this pcb trace.Arnoid said:I'm busy with the connections of the meter I use from hairball
Now I've connected +M with the + on my meter and the - of my meter to ground and the led is lighting up.(As in the schematic)
dirtyhanfri said:gyraf said:Farnell also has these cheap standard types:
Jakob E.
Hi
I got the meter that Jacob talks about from Farnell, and I have a question. It goes from 0 to 10. When the needle is in 2 (i.e.) it means itś reducing 2 dbs or 20%?
Maybe it's a obvius question, but I couldn`t be sure about this...
Thanks in advance for the answers
