mushibu09 said:
I know how to deal with mains electric....
Yeah - I'm not sure either why Udo is that concerned with you building an SSL compressor - it gets much worse when dealing with tubes as these are really high voltage and will kill you in an instance!
mushibu09 said:
and Dennisp, UK plugs are Green and Yellow Which is the Ground ( think if i remember it takes the excess and sends it to the 'ground or/and back to the plug) Live 230V is green and Neutral receives the 230V after been through 'appliance'.
Yes - that means that the Toroidal 230V (Brown) should be connected to the pin in the IEC plug that goes to Socket Live (Green) and the Toroidal 0V (Blue) goes to the pin in the IEC plug that goes to the Socket Neutral (Is that blue or black by any chance)?
The Ground (or Earth as it is commonly called) should be connected to pin1 on the XLR outputs and these will be connected to 0 via the output pins on pcb.
Check this page for standards on which pins on the IEC plug should be Live, Earth and Neutral:
http://www.electronics2000.co.uk/pin-out/iec.php
The wiring on the 30V side of the Toroidal transformer should be as I described but I see know that I named the wrong colours (I mentioned red twice - first one should be orange - sorry about that).
In the top left corner of the mounting side of the pcb, the 3 squares next to the place for the bridge rectifier (yes that was the name in english) are the ones I'm talking about when connecting the 30V side of the Toroidal transformer.
The correct order would be (those are the ones placed on the right side in the datasheet for the Toroidal transformer):
Top pin: orange (0V)
Middle pin: yellow (VSec) and black (0V) shorted together
Bottom pin: red (VSec)
Update: I call them pins as I've mounted pin rows (not sure what they are called in English)... they look like this:
http://www.el-supply.dk/?Gid=611&VNr=5556.02
And I've soldered the wires to wires with houses that fit (not sure again what it's called in English)... and they look like this:
http://www.el-supply.dk/?Gid=616&VNr=5595.03
The bridge rectifier would then be placed directly next to those pins and the + marked on the bridge rectifier must match the right top pin marked + on the pcb.
I hope that was more clear?
mushibu09 said:
and It was more what holes for what cable!
I'm not sure what you mean here - Are you talking about the holes in the rack box (front and back)?
In the back I have drilled holes for the XLR plugs that are about 15mm (and small 2mm holes for the screws).
For the IEC plug I actually just made a drawing on the back panel with a pencil by measuring the IEC plug and then cut it with a dremel with a fiberglass reinforced cutting wheel (remember to protect your hands and face as these are known to break and fly towards you at a dangerous speed!).
Instead of XLR plugs you could also use stereo female Jack connectors and these would probably need holes at about 6mm...
In the front I drilled holes for the Lorlins at about 9mm - I do know however that some prefer to make an extra aluminum plate inside the casing (behind the front panel) as to hide the nuts... then you would drill the 9mm holes on the aluminum plate and then 6mm holes for the shafts on the Lorlins.
About the metering - it depends on how you would place the LEDs (maybe a plastic or epoxy "mounting something" - but do mind not to cut too much in the front panel as it has to carry some weight)... as well as how big the LEDs you choose.
If that was not what you meant by what holes for what cable I do believe I did answer you...
Look at the schematics on page 2 in these pages: http://www.gyraf.dk/gy_pd/ssl/ssl.pdf
Positive regards
Dennis
