Walcar said:Hello,
I'm new here (from Paris, France) and have just finished building a SSL clone using PCB Grinder's PCB and a toroidal transformer (2X15V/1A)
When i measure voltage on + & - 15v points on the Pcb, my voltmeter show: 6,XX volts; i've checked the resistors value in the PSU section: they are all ok
Does somebody have an idea for something going wrong?
Probing with the meters red wire, meters black/common wire connected to 0V, meter set to read DC voltage, your meter will not show 6.xx VDC or your meters battery might be low/empty.Walcar said:When i measure voltage on + & - 15v points on the Pcb, my voltmeter show: 6,XX volts; i've checked the resistors value in the PSU section: they are all ok
spudstyle said:But I still have a problem with my power stage, sometimes, when I start the compressor, I don't have the +12 & +15 but have the -15 & -12. I need to power off and on again to have it. Capacitor problem ? Or diode bridge ?
Arnoid said:I builded my gssl a while ago and it worked from the first power up...
Last week I tryed to calibrate the ratio's, I use THAT2180BL for the VCA's and a 127K sidechain resistor.
I used a -15 db sine 1000 HZ testtone at the inputs and a 10db raise of the input signal this are the results:
2:1 4.70db (Has to be 5db)
4:1 3.03db (Has to be 2,5db)
10:1 1.59db (Has to be 1db)
These results are a little weird I think ? :
I also noticed that from the compressed output signal the left output has 1db more then the right output ??
What could be the problem of this ? The outputs are not symmetric ?
Somebody can help me out plz ?
phancak said:Arnoid said:I also noticed that from the compressed output signal the left output has 1db more then the right output ??
I recommend to replace the 127k resistor 91k and 50k trimer in series and calibrated ratio.
Arnoid said:phancak said:Arnoid said:I also noticed that from the compressed output signal the left output has 1db more then the right output ??
Thx any idea's for the output signal ?
Yes the transformer is suitable for use in the UK. Connect the brown wire on your transformer to L' (switched live) on your IEC. Connect blue wire on your transformer to N' (switched neutral) on your IEC. Connect PE' (Protective Earth) on your IEC to your metal chassis with a thick piece of yellow/green striped wire (via a dedicated nut and bolt separate from anything used to close the chassis, and make sure you scrape the paint or powder coating off the metal work so you get a good contact, and be sure to also use locking washers too so that it cannot accidentally work loose.)thepraqtice said:Have a couple of newbie power related questions... just starting to wire everything up.
This my power transformer:
https://dl.dropbox.com/u/4364451/gssl%20transformer.JPG
http://uk.farnell.com/jsp/search/productdetail.jsp?sku=9530266
Is it ok for use in the UK (230V)? On the primary it has 2x 115V but on Farnell it says it can handle 230V. This has confused me a wee bit... How would I wire primary's up to my power switch Earth, Live, Neutral connections and what rating fuse should I use with it? If I can use it... My power switch is an integrated IEC inlet/Fuse holder/Switch
http://gb.mouser.com/Search/ProductDetail.aspx?R=KM00.1205.11virtualkey69300000virtualkey693-KM00.1205.11
I am also using an Expat CRC board inline. How would I connect the secondary's to the CRC and where is the best place to connect CRC board to GSSL and mount the voltage regulator?
Sorry for newb questions, this part I really want to make sure I don't mess up...
Many thanks
Difference in level of +/-1dB is most likely caused by parts (resistors/VCAs) tolerances.Arnoid said:I also noticed that from the compressed output signal the left output has 1db more then the right output ??
Yes it's true but, like me, if you are bad in english (and in electronic), it's not easy to do a good search. Before asking a question, I try to use search... But a bad search cause I don't use good words.Harpo said:This thread could be 250 pages smaller if builders would read. Maybe try the search button.
Harpo said:Difference in level of +/-1dB is most likely caused by parts (resistors/VCAs) tolerances.Arnoid said:I also noticed that from the compressed output signal the left output has 1db more then the right output ??
Except an UFO dropped on your unit and now every resistor is blinking morse codes for whatever alien reason, probably every GSSL related question was answered numerous times.
My last answer to overall level imbalance was 8 pages ago. I stopped counting the others. If imbalance is happening when compressing, easiest fix might be to either tweak the 1K/120R voltage divider in front of the DBX202C substitution circuit or the 1K resistors at the audio-VCAs control port.
Your 100pF cap is OK. You won't find a cap with this dialectric where voltage rating in this spot will be your concern.spudstyle said:Ok, now my compressor is working but on my left channel, I got a ground noise. The right channel is ok, very low noise. My kit is from PCBGrinder and a capacitor was missing in the package (cause the BOM say 9x100pf and really need 10). I find another capacitor at home that is 100pf but not the same size cause it's a 500v (see attached picture). So this capacitor can be the problem ? In this case, what type of capacitor I need ? 50v, 100v ? I don't have the reference of PCBgrinder kit capacitor.
Thanks for your help.
