rearturo said:
Can you kindly direct me as to where the 0V reference is on the PCB please?
echo answer "the center pin of the aux.12VDC connector might come handy, or any spot at the big filled pcb traces"
And what do you mean exactly by the aux. 12VDC?
The auxiliary 12VDC supply rail, coming from the 7812 voltage regulator, maybe useful for supplying relais, incandescent lamps, LEDs,..., as you don't want any additional load at the 78L12. This additional/optional on board +12V supply rail goes to a 3-pin connector. The center pin of this 3-pin connector that connects to 0V reference voltage is the pin in the middle. The pcb silkscreen has this connector labled "+12V 0V NC, RELAY AND LIGHT POWER"
