Murdock said:
Yesterday I powered my unit on for the first time. I'm happy that it even powered on without exploding because I really don't know nothing about electronics...
Anyway, one meter LED illuminated very bright for like 3 seconds than it went off. I have the + soldered on to the 12V pad and the - to the 0V pad. Is that right? The meterLED has an internal 600 ohm resistor. Could it be that this is not enough?
Other than that, signal passes through the unit but the controlls don't work...
I measured some points. (http://postimg.org/image/jlqlt1zy5/) All measurements were taken without signal passing through, black probe on ground pin on the IEC and red probe on the pads.
The controll board receives 12V.
Are these OK? Where should I start looking for the fault?
Hi Murdock.
Great job measuring the voltages on the supply and regulators..
Now, if you can, measure them for the two 12V regulators and the supply voltages on the IC pins as well, that would help take you a step forward
600ohms suits 15mA current draw/2V voltage drop across LED perfectly. I dont see why this would blow the LED, but I could be wrong, so hopefully someone else will verify. (You should also make sure the 600ohms refer to an internal resistor in series with the LED and not "just" the meter circuit rating.
Also, please share if you are using a 2 x 18V transformer.
Do you have any mods installed?
Does the bypass switch seem to do anything at all?
Could you share a picture of your work (top and bottom)?
Gustav
