Hammond Box measurement
Norfolk - UK
This is an end view of the Hammond 1455T1201 enclosure:
As you can see it is an extrusion with a slide in section at the bottom that I have circled in red. What I want to do is use the slide in part as the top but replace it with a plain sheet of aluminium which I can have drilled and engraved for the controls and legend I need. What I cannot do is work out the correct width a and thickness for the replacement aluminium panel. I have attached the 2D drawing provided by Hammond but I am not sure if that is sufficient to work out what I need. On the attached drawing is an email from where you can request a 3D CAD file of the enclosure which presumably is sufficient to answer the question. However, my 3D CAD skills are close to zero so can someone look at this for me?
  • 1455T1201.zip
    266.8 KB
Spec sheet says minimum thickness of aluminum is 1.5mm....unless that's just the extrusion part...still, ..I'd probably guess that would be it since it's almost looking like that section would be 2mm maybe a bit less.... But I realize that's not scientific....or helpful if not able to get it and go try out some sample pieces....
