nielsk said:
Thanks for you reply, Grummy... so it looks like I should have received the op amp board then.
I would sort of figure that, as the op amp would be a big part of what makes this different from all the other LCR eqs...
The pics in the download clearly show the pk/th switch wiring from every angle imaginable, but I find nothing concerning the xlr}ins switch. No explanation of what this is or how it is supposed to work & be wired.
Like most I want a bypass switch, if this can be configured as such I need information, as with these black PCBs w/ ground planes, I can't trace anything out.
You can figure thois out easy from schemo.
For use with xlr/ins/byp option, switch is SPDT ON-OFF-ON toggle.
Center of switch connected to 2.
In mid position, all relays are energized.
When BYP1/2 relays are not energised (/BYP1, /BYP2 points are connected), it is bypass.
nielsk said:
Hm. All questions you asked is just a matter of some minutes to stare into schematics and meditate
Forum topics actually take a lot of my time, it is like understand what happened, check with the schemo, etc.
If I am busy with my stuff - sorry. I checking the threads couple of times every week, so...
if this is the matter of hardcore troubleshooting, I answer as soon as I can,
the questions like see the bom/schemo are left for when I have a free time.
Example. Let's assume we not boost/cut anything.
Than, signal drop path is r21(22k) to (r22(5k1) in parallel to mid cut (25k)), or mid boost(25k) to r22,
so, we need 25->5.1 feedback resistors coefficients to restore to unity gain.
See the schemos where 2520 used and you find that 25k/5k1 is good point to start with. Etc.
BTW, strange, we included the "original" amp boards with kits.
One of duded told he have not received it or lost when unpacking, so, we resent.
So, if this happened with you too, just drop me an email, will send the He amp board, of course, no charge for this.
