Not sure there's anyone paying attention to this thread, but here goes...
I'm just in the process of wrapping up my mouser order for my components and not being a genius when it comes to this stuff wanted to state my understanding of the less well documented parts of this build for clarity's sake.
The output transformer can be setup for 1:1 or 1:2. At some points in this thread I thought that the choice was completely arbitrary, but it seems to be now, that the correct thing to do is to use 1:1 when the input transformer is included, and 1:2 when the balanced line receiver is being used.
It's my understanding that there is a 6db loss when using the balanced line receiver, as the That1246 is a 1240 series component, and the 6 means -6db of gain. There are other 1240 series ics available, but the 1246 seems to be the best for input headroom.
Because I'm using the cascode amp from Igor's F76, I'm using R12 : R15 == 2k49 : 511R, which Igor states is suitable for his amp for 1:2 operation (are these the only things required for 1:2 operation?). Additionally, when those values are used, it's also mentioned that C7 should be 330 pf.
R17 is dependent upon the relays used. It's recommended that 12v relays are used instead of the original 5v ones that were specified.
The following ones were recommended: http://uk.farnell.com/jsp/search/productdetail.jsp?sku=9913890&CMP=i-bf9f-00001000 and they have a 1K coil resistance.
According to the SCHEM_PS_IO_RELAYS.png file, to calculate the resistance required for R17 when using relays with 200R coil resistance, the following should hold true:
r17 = (voltage required at r17 / (voltage required at relays / coil resistance));
r17 = (1.25 / (5 / 200)) = 50R.
It should be noted that I just played with the numbers until they made sense, as I find the words in the schematic less than clear personally.
Also worth noting is that the schematic says..."possible to use 12v relays with 9v on each relay".
As I understand it, relays are switched by the current passing through the coil and magnetising the switch. For the 12v relay, that means that the switching current is (found the formula on a random electronics site, but it makes sense to me...):
coil current = (supply voltage / coil resistance), so:
blah = (12v / 1000R) = 0.012 Amps.
Looking at the lm317 data sheet, it looks like this one is setup as a precision current limiter. Where limit current i = 1.2 / R.
So if the coil needs 0.012 amps to trigger it, then that must mean:
R = 1.2 / i, which is:
R17 = 1.2 / 0.012, which gives 100R.
Performing the same calc using the schematic formula, and substituting the coil resistance in for the 12v coils and also substituting the 9v for the 5v gives:
r17 = (1.25 / (9 / 1000) = 138.8888889R
which is ok if 9v is an acceptable voltage, but obviously if 12v is used instead, then it matches up with my other result...
r17 = (1.25 / (12 / 1000) = 104R.
(well near enough...the discrepancy is 1.2 vs 1.25).
So, after all that, I've just got one simple question (and congrats for reading this far!):
If I go ahead and use those 12v relays, should I use:
a) 100R.
b) 138.8888889R.
c) 104R.
Answers on a postcard.
Kaz
