I certainly agree. However, how do you reconcile the fact that a majority of listeners now listen via headphones or car audio with overinflated LF response?
I would not say for sure "majority" so I don't agree to a certain degree as I don't think it's universal.
In the 90's, Discams, walkmans and car radios used to have a "Bass Boost" or "Mega Bass" control in the front panel, normally with 3 levels of bass boost,
with the trend to have the "Bass Boost" included in the actual audio, or just start using the region under 80hs that we listen and feel, that went from 2000 on, I don't see any present day equipment with a "Bass boost" button on the front panel. They are normally inside a Menu/audio/settings. It happened like that in the now obsolete iPod, and it's like that in modern car radios and also inside Spotify apps and similar.
There's a lot of music nowadays that takes usage of the sub frequencies, and the good productions/mixes still sound good to me in any reproduction system, being it Bluetooth speaker, car radio, or headphones.
There's an average of Low end energy in commercial records, some a bit above and some a bit under that average.
But I was talking about being really off the average, having so little bass that you can't feel the foundation of the Bass Drum and Bass, or having to much and distort and fart out any modern reproduction system.
I know the music I produce is for people who will listen on their stereo, but if I had to address a younger generation I wouldn't know what to do.
Well,
you would just do the same as I do, I ask the clients for 4 to 5 songs that they like and artists that inspired them for their work,
then you can calibrate your brain with that and make your work be on that average.
Personally I'm constantly updating myself to the new trends and to the clients aesthetics, I don't want to ever be outdated and say something like "the only music that sounded good was in the 70s and present music is just crap", I don't feel that and I'm not entering that old cycle were a generation always says that the new generation is lost.
I grew up in the 90s, and I remember quite well how the average person listened to music, they had very cheap consumer compact hifi units at home that sounded like crap had no sub and not much above 10khz then no one had the speakers in a good position any way, then there were those portable boom boxes that sounded pretty bad also, walkmans and cassettes sounded terrible for each listen the sound would degrade a lot, then most consumer headphones/earbuds at the time were miserable also.
Average standard Car Radios and car speakers were also quite bad.
Give me a Bose/JBL bluetooth speaker playing audio from iphone with spotify at any time compared to any of the systems I described.
Also give me any Apple Earbuds compared to any earbuds from the 90's.
Or any 80€ Modern Pioneer car Radio with 80€ JBL (or any know brand) car speakers to any car systems from the 90s, 80s or 70s
I still gladly accept any 90s Hi-End Hifi systems though
I'm equally at loss with PA systems that have the so-called "bass contour", that amounts to about +14dB at 50 Hz.
I've been an adept of the straight-ish line for too long.
In Live Sound I always run the subs in Mono and I send a different mix to them, I think the term is "subs on aux send",
I then have full control of the subs and independent of the Tops/line array.
I find that usually my master send to the SUBs is -10dbs to -15dbs compared to the level I send to the Tops Line Array.
