mus1k_freak
I was just about to write back and say that sowter has some that are very similar, the original helios used lustraphone transformers, which are no more, maybe you could find a few vintage used ones if you really wanted to go original. Helios, ampex, quad 8, neve, etc all started fairly close to the same time, and a lot of the same people and designers worked on more then one brand, which is why some of them share similar topology. I think most input transformers would sound great with this pre, you could use cinemag, lundahl, ed Anderson, sowter, etc, each one would give you a unique flavor. I plan on running mine unbalanced out to save some money on the iron for a multichannel build, however its set up to drive a output transformer just fine, so if you would rather go that route it would be no problem to add one to the output. its designed to run off of a +24 single rail, I included the power supply into the pcb board all you need is a 120 (or whatever your country has 220, 110 etc) to 24v, which is super cheap.
mitsos said:Which Q8 amps are these similar to? I looked at some schematics but the stuff I have (CA127, for example) looks like an opamp to me.
Is there info on the input transformers for these (ratio/size/etc)? Their -20 input is not a pad, but using the center tap of the input trafo secondary which I think is pretty cool.But does that imply a 1:10+10 input trafo?
EDIT: found some info on sowter's site... their 7490 is supposed to be a replacement for the original and is 1:10 with a 1:1 tap...
