Help Needed with NT1a Microphone Repair!
Jobair Ahmed
Member
BANGLADESH
I'm facing a tricky issue with my NT1a microphone and would really appreciate some guidance or tips from anyone here who might have experienced something similar.
My NT1a microphone isn’t producing any sound. However, when I expose it to sunlight, it starts working again but only lasts about four to five minutes before the sound cuts out.
Based on some Googling, it seems to be a moisture issue inside the mic. Does this sound right to anyone? Has anyone dealt with this type of problem before and successfully fixed it?
I'm also considering using a replacement capsule, specifically the TZT CK12 style or Baifeli K87 capsules I saw on AliExpress. Does anyone have experience with these or other aftermarket capsules? Are they reliable and do they match the quality of the original parts?
Link 1 : https://www.aliexpress.com/item/1005005675808696.html
Link 2 : https://www.aliexpress.com/item/1005005643450488.html
Link 3 :https://www.aliexpress.com/item/1005005997124664.html
or something like them.
Any advice on how to repair this issue or feedback on using the replacement capsules would be super helpful!
Thank you all in advance!
What voltage can you measure between ground and that exposed via ("before" that 4.7meg resistor)?
in-between ground and before and after 4.7meg resistor i measured
before 4.7meg it shows 75.5v and after the 4.7meg 51v
Can you take a photo of where both ends of the red wire connect to? The terminal on the capsule (but viewed from the back of the capsule), and the end that gets soldered onto the PCB?
